Best overall
Dell UltraSharp U2715H
See at Amazon
The Dell UltraSharp U2715H ($549) is just about the best monitor money can buy for most people. It features an in-plane switching (IPS) panel, which means you'll have excellent viewing from side angles and fantastic color reproduction. With a resolution of 2560 x 1440, you're getting better-than-HD picture quality, so you shouldn't notice any pixels, even when sitting close to it. The monitor is fully adjustable, and it's able to tilt, swivel, rotate and adjust to whatever height is comfortable for you.
Bottom line: This screen is an excellent choice with an ultra-thin bezel for more display and less distraction.
One more thing: It has a plethora of ports and connections.
Why the Dell U2715H is the best 27-inch display
Dell's UltraSharp U2715H is a fantastic monitor. The ultra-thin bezel means more screen and less distraction so that you can stay focused on the task at hand, and its six millisecond response time means you'll not notice ghosting or judder, so it's great for gaming. Perhaps the best part is the U2715H's plethora of media connections, so you won't have to compromise on what peripherals get to stay plugged in and which ones you have to switch out all the time.
Here's a list of all available ports:
  • 2x HDMI/MHL.
  • Mini DisplayPort.
  • DisplayPort 1.2.
  • DisplayPort out.
  • Audio line out.
  • five USB 3.0 downstream ports (one for battery charging).
  • USB 3.0 upstream.
With a resolution of 2560 x 1440, we're talking about QHD viewing for enhanced productivity and gaming. It's also not too out of reach for most budgets at $549.
Best Budget
BenQ GW2765HT
BenQ GW2765HT
See at Amazon
The BenQ GW2765HT ($329) is a great middle-of-the-road option for folks who don't want to spend too much but still need a high-performance monitor. For the price, you get a 2560 x 1440 resolution IPS panel with great viewing angles, two 1W speakers, modes for zero flicker and low blue light to stave off eye fatigue, and more.
Bottom line: This monitor is simply designed, so if you're all for keeping up with the Joneses, it's not the most stylish. But it's practical and inexpensive at $330.
One more thing: It's a really bright display, so take this as a fair warning if you work in a dark environment.
4K
Dell P2715Q
Dell P2715Q
See at Dell
If 4K is your bag, you can't do much better than Dell's P2715Q ($549.99), which has an IPS panel, all the media connections you could want, and swivel, tilt, rotation and height adjustments out the wazoo. This puppy refreshes at 60Hz, which is lightning-quick for a 4K monitor, and it also means you'll notice very little ghosting or other visual artifacts. It's great for gaming, watching movies, or just about anything else you can throw at it.
Bottom line: Solid 4K monitor with tons of features and capabilities, and it isn't ridiculously priced.
One more thing: It has a response time of just eight milliseconds.
Gaming
AOC Agon AG27
AOC Agon AG271QX
See at Amazon
One of the first things to know about the AG27 from AOC is that you can have a great gaming time whether you use NVIDIA or AMD graphics. That's because you can get the same basic monitor with either G-Sync or FreeSync support, with the difference being the price; G-Sync costs a bundle more.
Otherwise, you've got a stunning 27-inch 1440p monitor with a 144Hz refresh rate and one-millisecond response time. So far it ticks all the boxes. The AG27 also has connectivity coming out of its eyeballs, with VGA, Dual-Link DVI, HDMI 2.0, HDMI-MHL and DisplayPort connections. There are also four USB 3.0 ports (one of which is a dedicated fast charge port for your smartphone) as well as two integrated 3W speakers and an audio line in and headphone out.
Bottom line: It's a gorgeous display with the option for FreeSync and G-Sync. (The G-Sync version costs $549.)
One more thing: The 144hz refresh rate and a response time of just one millisecond make this ideal for a gaming machine.
Conclusion
When it comes to 27-inch displays, you're heading into 1440p territory and thus for gaming, you'll definitely need to ensure you have a capable rig to handle the resolution. Turning things down to 1080p could risk some blurriness on larger panels. For everyone else, you really can't go wrong when selecting a monitor from our guide. These are all fantastic monitors in their own right, but Dell's UltraSharp U2715H takes the number one spot.
Best overall
See at Amazon
The Dell UltraSharp U2715H is just about the best monitor money can buy for most people. It features an in-plane switching (IPS) panel, which means you'll have excellent viewing from side angles and fantastic color reproduction. With a resolution of 2560 x 1440, you're getting better-than-HD picture quality, so you shouldn't notice any pixels, even when sitting close to it. The monitor is fully adjustable, and it's able to tilt, swivel, rotate and adjust to whatever height is comfortable for you.
Bottom line: For $450, this screen is an excellent choice with an ultra-thin bezel for more display and less distraction.
Updated September 11, 2017: We replaced the Acer Predator XB271HU with the AOC Agon AG271QX, and removed the ASUS P277Q.
