Best Replacement Charger for Huawei MateBook X Pro in 2022
MateBook X Pro
MateBook X Pro
The 60-watt Anker PowerPort is a compact USB-C charger replacement for your Huawei MateBook X Pro. It's well-reviewed, it's reliable, and it's relatively affordable.
Anker PowerPort 60 W
A replacement for your MateBook X Pro's charger.
Who should buy this replacement charger
Anyone who needs a straight replacement for their MateBook X Pro's charger can definitely benefit from the Anker PowerPort. It keeps things simple with a single USB-C port on the front, and it's small enough to easily fit into a bag or pocket on the side of a laptop sleeve.
Is it a good time to buy this replacement charger?
Yes, if you need a charger for your MateBook X Pro, there's not much sense waiting for an upgraded or better version. This one is proven to work well and is relatively affordable.
You don't need to track down an original MateBook X Pro charger
If you misplaced or damaged the charger that originally came with your Huawei MateBook X Pro, you don't have to go through the hassle of tracking down a new, original charger. Thanks to the laptop using USB-C ports to charge, our top pick — the Anker PowerPort — gets the job done and is readily available.
It's compact, it's affordable, and it will charge your MateBook X Pro with up to 60 W of power.
It plugs straight into a power outlet with no extra cable to worry about, and its compact design means you can easily slip it into a laptop bag or the pocket on the side of a sleeve. It has a single LED on the front that lights up when your laptop is charging, and there's a single USB-C port with Power Delivery on the front that offers 60 W of charging power.
Anker's charger is relatively affordable at about $33, and it comes with an 18-month warranty for some peace of mind. As a bonus, it works with a ton of laptops, tablets, and other devices that use USB-C for charging, allowing you to charge some other hardware when your laptop is topped up.
Alternative to the Anker PowerPort 60-watt charger
Anker's PowerPort is the best choice for anyone who needs a standard laptop charger for their MateBook X Pro, but there is an option that can offer three extra USB-A ports for plugging in additional accessories while your laptop charges.
Nekteck four-port charger
One USB-C and three USB-A ports.
Reasons to buy
Compact design
Offers 60 W of charging power
LED on the front gives you charging status
18-month warranty included
Reasons to avoid
Can find chargers with extra ports
Nekteck's charger offers the same 60-watt charging through its USB-C port, but it also has three USB-A ports with 12 W of charging power. It connects back to the wall outlet with a four-foot cable, and it has a one-year warranty.
Bottom line
The Anker PowerPort 60-watt charger is an ideal replacement for your Huawei MateBook X Pro. It's affordable, it's compact, and it's reliable. It nearly matches the original charger's power output (about 62 W), it comes with an 18-month warranty, and an LED on the front lets you know it's working when you plug it in.
Cale Hunt
Contributor
Cale Hunt brings to Windows Central more than eight years of experience writing about laptops, PCs, accessories, games, and beyond. If it runs Windows or in some way complements the hardware, there’s a good chance he knows about it, has written about it, or is already busy testing it.
