Best Turtle Beach Stealth 600 Accessories and Replacement Parts
The Turtle Beach Stealth 600 wireless headset is an excellent well-rounded and affordable headset for Xbox One players, but you can make your experience with it even better by investing in some accessories. In addition, if your ear cushions or charging cable get damaged, there are replacements available. Here's a short list of the Stealth 600 accessories and parts we recommend.
Ear Force HS1 Universal Gaming Headset Stand
Headset display
If you want to display your Stealth 600 when it isn't in use, or simply want to keep it from sitting on a surface, the Ear Force HS1 Universal Gaming Headset Stand is a great accessory to have. It's good looking, simple, functional and affordable.
AC-to-USB
This adapter allows you to turn any outlet into a place to charge the Stealth 600. It's designed for smartphones, but since the Stealth 600 uses a micro-USB cable, this adapter can work for the headset, too. The dual USB port design also allows you to charge something else alongside the Stealth 600, like an Xbox controller that has rechargeable batteries.
Replacement cable
If the micro-USB cable that came with your Stealth 600 breaks, you'll need to replace it. This cable is six feet long, which gives you plenty of room to work with when choosing a place to charge your headset. In addition, it's thickly braided with nylon, making it durable and unlikely to tear or split.
Replacement ear cushions
If the cushions in your Stealth 600 tear, your headset experience will be significantly less comfortable. Thankfully, Turtle Beach offers replacements on its website, and they're pretty cheap at just $4 each.
All of these accessories and parts are great to have for your Turtle Beach Stealth 600, and since they're all on the cheaper side, you might want to buy all of them. However, if you had to choose, I think it's most important to have the Rankie Micro USB Cable, as well as a pair of the replacement ear cushions. The former will ensure you'll likely never need to buy a replacement cable ever again, while having the latter ahead of time will allow you to easily swap out the damaged cushions for the new ones right away.
Brendan Lowry is a Windows Central writer and Oakland University graduate with a burning passion for video games, of which he's been an avid fan since childhood. You'll find him doing reviews, editorials, and general coverage on everything Xbox and PC. Follow him on Twitter.
